Possible thread synchronisation bug in rtems networking
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Sun Mar 2 11:13:38 UTC 2008
Hi Graham,
it is always good to have a close look at important code, but I
currently do not see the real problem.
Without rechecking everything, I guess that any wakeup event will be
sent to the task, which has posted its ID in so->so_pgid. When
rtems_event_receive is called, the current task has not yet posted its
task ID to this field, AND the code is still running unter the
protection of the networing mutex. So I don't see, why somebody else
might already have sent an event to a task, when the task's ID is not
yet known.
Only when tems_bsdnet_event_receive is called, the networking mutex is
released, but the events returned from this call are not lost.
What did I miss in your concerns?
wkr,
Thomas.
Graham Darnell schrieb:
> Hi,
> I am concerned that there is a thread synchronisation problem in the
> rtems networking code.
> All calls to rtems socket functions are protected by a single mutex, but
> in order to prevent the networking stack from seizing up in the presence
> of long-running calls, there are two mechanisms in place. One of these
> deals with blocking reads, the other deals with functions like connect,
> accept, and close (in the presence of SO_LINGER), which need to wait for
> a connection or disconnection.
> It is this second mechanism that concerns me.
> It consists of two functions:
> soconnsleep: this function is called in connect, accept, and close in
> the context of a client thread of arbitrary priority in order to wait
> for the connection state to change.
> soconnwakeup: this function is called in the context of a high priority
> networking thread when the connection state changes
> The idea is that soconnsleep releases the global networking mutex then
> waits on an rtems event which is produced some time later when
> soconnwakeup is called. soconnsleep then reacquires the global
> networking mutex and carries on as normal.
> The source code is reproduced below.
> My concern is with the call to rtems_event_receive() marked with the
> comment 'Soak up any pending events'. And my fear is that this will,
> under unfavourable thread scheduling conditions, soak up not only the
> pending events but also the actual connection/disconnection event that
> we are waiting for. The result being that we never return from
> soconnsleep and the application thread is largely toast.
> What I am really seeking is some confirmation that my fears are correct
> from someone who knows this code better than me.
> I do have a couple of proposals for a solution, but I guess that can
> wait until my fears have been verified or refuted.
> Best regards
> Graham Darnell
>  * Wait for a connection/disconnection event.
> *int*
> soconnsleep (*struct* socket *so)
>         rtems_event_set events;
>         rtems_id tid;
>         rtems_status_code sc;
>          * Soak up any pending events.
>          * The sleep/wakeup synchronization in the FreeBSD
>          * kernel has no memory.
>         rtems_event_receive (SOSLEEP_EVENT, RTEMS_EVENT_ANY |
> RTEMS_NO_WAIT, RTEMS_NO_TIMEOUT, &events);
>          * Set this task as the target of the wakeup operation.
>        * if* (so->so_pgid)
>                 rtems_panic ("Another task is already sleeping on that
> socket");
>         rtems_task_ident (RTEMS_SELF, 0, &tid);
>         so->so_pgid = tid;
>          * Wait for the wakeup event.
>         sc = rtems_bsdnet_event_receive (SOSLEEP_EVENT, RTEMS_EVENT_ANY
> | RTEMS_WAIT, so->so_rcv.sb_timeo, &events);
>          * Relinquish ownership of the socket.
>         so->so_pgid = 0;
>        * switch* (sc) {
>        * case* RTEMS_SUCCESSFUL: * return* 0;
>        * case* RTEMS_TIMEOUT:    * return* EWOULDBLOCK;
>        * default*:               * return* ENXIO;
>  * Wake up a task waiting for a connection/disconnection to complete.
> *void*
> soconnwakeup (*struct* socket *so)
>        * if* (so->so_pgid)
>                 rtems_event_send (so->so_pgid, SOSLEEP_EVENT);
> rtems-users mailing list
> rtems-users at rtems.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
      http://www.imd-systems.de/pgpkey_en.html
