can not install rtems4.8-tools-autotools-17.exe
阎淼 yanmiaobest at gmail.com
Tue Mar 4 04:35:03 UTC 2008
I use the installer, mingw is installed to c:\mingw
MSTS is installed to c:\msys\1.0
all are their default directory
It works fine on my laptop, but failed on my workstation. May be it's
because I didn't use the administrator account.
BTW: if I use the mingw tarball, how can I install the devel tools?
2008/3/4, Chris Johns <chrisj at rtems.org>:
> ?? wrote:
> > hi,
> >   I am installing rtems development enviroment on windowsXP.
> >   I followed the wiki page, installed mingw, MSYS-1.0.10.exe and
> > msysDTK-1.0.0.exe into their default directory.
> >   but when I install the rtems4.8-tools-17.exe, a message box comes up saying
> >   "MinGW not installed. Please install MinGW from www.mingw.org"?
> >    is there something wrong with my process?
> Where did you install MinGW and MSYS ?
> Did you just use the MinGW etc tarballs or did you use the installers ?
> Regards
> Chris
