Stack Checker in rtems-4.8.0 - is it broken?
Robert S. Grimes
rsg at alum.mit.edu
Wed Mar 5 02:04:33 UTC 2008
Joel Sherrill wrote:
> Robert S. Grimes wrote:
>> Hi,
>> Does the stack checker still work? My app using powerpc/virtex BSP
>> seems to fail on startup when the stack checker task is created in
>> taskinitusers.c/_RTEMS_tasks_Initialize_user_tasks_body(). I get an
>> exception 7 - here is the dump:
> There is no stack checker task. It is a user extension.
That makes infinitely more sense! ;-) I was misled by the context -
silly me.
> It works in 4.8 as far as the test program stackchk.exe goes.
I figured you'd say that...
> You are on the "BSP initialization stack" at this point in the program
> initialization. I suspect you have blown your initialization stack
> or the RTEMS workspace and the BSP initialization stack overlap.
> Thus when the stack checker writes the pattern for the first
> created task, it destroys the stack you are running on.
> Does this make sense?
Sure, if that is indeed what is going on. I'm not sure where to look on
this, and I won't be able to check on it until Friday (FWIW - the only
truly frustrating thing about my project is I only work 18-20 hours
during two days a week, and I always seem to be finding problems at the
end of one day, and I can't get back to it until several days later!)
Anyway, I'll look into it then, and report back - until then, assume it
is in my BSP...
Thanks!
-Bob
>> Exception handling initialization done
>> opb_intc_init: mexception handler called for exception 7
>> Next PC or Address of fault = A5A5A5A4
>> Saved MSR = 0
>> R0 = A5A5A5A5
>> R1 = 4A7EB4
>> R2 = 4853A8
>> R3 = 1
>> R4 = A5
>> R5 = 0
>> R6 = FEFFFFFF
>> R7 = 490000
>> R8 = 490AAC
>> R9 = 4A9C78
>> R10 = 1
>> R11 = 4A9C78
>> R12 = 0
>> R13 = FFFEAAFC
>> R14 = FFFFFFFF
>> R15 = FFFFFFFF
>> R16 = FFFFFFFF
>> R17 = FFFFFFFF
>> R18 = FFFFFFFF
>> R19 = FFFFFFFF
>> R20 = FFFFFFFF
>> R21 = FFFE2E6C
>> R22 = FFFE0000
>> R23 = FFFE0000
>> R24 = 0
>> R25 = 490984
>> R26 = 1
>> R27 = 0
>> R28 = 490000
>> R29 = 490C2C
>> R30 = 4A0F38
>> R31 = A5A5A5A5
>> CR = 28008022
>> CTR = 0
>> XER = 20000000
>> LR = A5A5A5A5
>> MSR = 0
>> DAR = 0
>> Stack Trace:
>> IP: 0xA5A5A5A4, LR: 0xA5A5A5A5
>> --^ 0x00000000
>> unrecoverable exception!!! Push reset button
>> Turning off the stack checker allows my application to proceed
>> normally...
>> Any ideas? Thanks!
>> -Bob
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
