Sample example not working: fileio.exe
Wed Mar 12 14:12:22 UTC 2008
Thomas Doerfler wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Vinod,
> can you give us more information about the disk/disks and interfaces
> installed in that computer?
And how you are attempting to execute it.  It will not
run directly from the Linux command line.   RTEMS is
an OS that directly accesses hardware.  The application
includes the OS and must be booted just like Linux.
qemu is handy for this since it is a good virtual PC.
--joel
> wkr,
> Thomas.
> Vinod Kulkarni schrieb:
> | Hi Thomas,
> |     Yes, I am testing it on 386 PC (computer).
> | Regards
> | Vinod
> | -----Original Message-----
> | From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> | Sent: Wednesday, March 12, 2008 4:58 PM
> | To: vinodk at tataelxsi.co.in
> | Cc: rtems-users at rtems.com
> | Subject: Re: Sample example not working: fileio.exe
> | Vinod,
> | one thing you should check: currently the disk interface is based on a
> | IDE driver. Do you possibly have fileio.exe running on a machnie, that
> | has a modified disk interface (like SATA...). I have no experience, how
> | the RTEMS driver would cooperate with NON-PATA Interfaces.
> | wkr,
> | Thomas.
> | | Hi,
> | |     I have built RTEMS for i386 (pc386) on Linux. I could execute sample
> | | examples such as hello.exe. However, when I tried to execute
> fileio.exe, I
> | | am not able to see any output on the console. But as per the document
> | | fileio.doc, it needs to display options such as "s" etc. Could
> anyone tell
> | | me what could be the problem?
> | | Regards
> | | Vinod
> | | The information contained in this electronic message and any
> | attachments to this message are intended for the exclusive use of the
> | addressee(s) and may contain proprietary, confidential or privileged
> | information. If you are not the intended recipient, you should not
> | disseminate, distribute or copy this e-mail. Please notify the sender
> | immediately and destroy all copies of this message and any attachments
> | contained in it.
> | | Contact your Administrator for further information.
> | | _______________________________________________
> | | rtems-users mailing list
> | | http://rtems.rtems.org/mailman/listinfo/rtems-users
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s)
> and may contain proprietary, confidential or privileged information. If
> you are not the intended recipient, you should not disseminate,
> distribute or copy this e-mail. Please notify the sender immediately and
> destroy all copies of this message and any attachments contained in it.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
> ~     http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFH188bwHyg4bDtfjQRAk67AJ0epgjbJBPv/tYPVkkohUz5TcrosACcDUGM
> zJzx80ixdHALZC75tWxx64E=
> =ewYD
> -----END PGP SIGNATURE-----
