Sample example not working: fileio.exe
Wed Mar 12 17:43:14 UTC 2008
Thomas,
It is probably just a setup issue on my side but the IDE
driver locks up during initialization on qemu before Init
runs.
Program received signal SIGINT, Interrupt.
ata_process_request_on_init_phase (ctrl_minor=0, areq=0x15da10)
at ../../../../../current/c/src/libchip/ide/ata.c:1422
1422 (!(byte & IDE_REGISTER_STATUS_DRDY)));
(gdb) bt
#0 ata_process_request_on_init_phase (ctrl_minor=0, areq=0x15da10)
#1 0x0010683c in ata_initialize (major=3, minor_arg=0, args=0x0)
at ../../../../../current/c/src/libchip/ide/ata.c:1291
#2 0x0011109b in _IO_Initialize_all_drivers ()
at ../../../../../../current/c/src/../../cpukit/sapi/src/io.c:97
#3 0x00111046 in rtems_initialize_executive_early (
configuration_table=0x144460)
at ../../../../../../current/c/src/../../cpukit/sapi/src/exinit.c:239
#4 0x00108d3c in boot_card (argc=0, argv=0x0, envp=0x0)
at
../../../../../../../../current/c/src/lib/libbsp/i386/pc386/../../shared/bootcard.c:91
#5 0x00100071 in zero_bss ()
at
../../../../../../../../current/c/src/lib/libbsp/i386/pc386/start/start.S:184
#6 0x00000000 in ?? ()
Stepping into the check, I see this:
(gdb) s
102 uint32_t port = IDE_Controller_Table[minor].port1;
(gdb) s
105 if (reg == IDE_REGISTER_DATA_WORD) {
(gdb) s
111 inport_byte(port+reg, bval1);
(gdb) p port
$1 = 496
(gdb) p reg
$2 = 7
(gdb) p/x port
$3 = 0x1f0
So it is hanging on the first IDE interface's status.
My qemu invocation is:
qemu -M isapc -m 8 -boot a -fda /home/joel/qemu/pc386_fda \
-hda fat:/home/joel/qemu/hd -serial stdio -s
I don't know if this is THE problem here or not but it is
stopping for me. :)
--joel
Thomas Doerfler wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Vinod,
> can you give us more information about the disk/disks and interfaces
> installed in that computer?
> wkr,
> Thomas.
> Vinod Kulkarni schrieb:
> | Hi Thomas,
> |     Yes, I am testing it on 386 PC (computer).
> | Regards
> | Vinod
> | -----Original Message-----
> | From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> | Sent: Wednesday, March 12, 2008 4:58 PM
> | To: vinodk at tataelxsi.co.in
> | Cc: rtems-users at rtems.com
> | Subject: Re: Sample example not working: fileio.exe
> | Vinod,
> | one thing you should check: currently the disk interface is based on a
> | IDE driver. Do you possibly have fileio.exe running on a machnie, that
> | has a modified disk interface (like SATA...). I have no experience, how
> | the RTEMS driver would cooperate with NON-PATA Interfaces.
> | wkr,
> | Thomas.
> | | Hi,
> | |     I have built RTEMS for i386 (pc386) on Linux. I could execute sample
> | | examples such as hello.exe. However, when I tried to execute
> fileio.exe, I
> | | am not able to see any output on the console. But as per the document
> | | fileio.doc, it needs to display options such as "s" etc. Could
> anyone tell
> | | me what could be the problem?
> | | Regards
> | | Vinod
> | | The information contained in this electronic message and any
> | attachments to this message are intended for the exclusive use of the
> | addressee(s) and may contain proprietary, confidential or privileged
> | information. If you are not the intended recipient, you should not
> | disseminate, distribute or copy this e-mail. Please notify the sender
> | immediately and destroy all copies of this message and any attachments
> | contained in it.
> | | Contact your Administrator for further information.
> | | _______________________________________________
> | | rtems-users mailing list
> | | http://rtems.rtems.org/mailman/listinfo/rtems-users
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s)
> and may contain proprietary, confidential or privileged information. If
> you are not the intended recipient, you should not disseminate,
> distribute or copy this e-mail. Please notify the sender immediately and
> destroy all copies of this message and any attachments contained in it.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
> ~     http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFH188bwHyg4bDtfjQRAk67AJ0epgjbJBPv/tYPVkkohUz5TcrosACcDUGM
> zJzx80ixdHALZC75tWxx64E=
> =ewYD
> -----END PGP SIGNATURE-----
