LEON2 console ringbuf.h
John Pickwick john.pickwick at free.fr
Sat Mar 15 18:10:12 UTC 2008
Hi Jose,
to do this I simply modified the .cfg file (leon2.cfg) and added a CONSOLE_USE_INTERRUPTS compilation directive to the CFLAGS line.
It works in 4.7.1.
John.
  ----- Original Message -----
  To: rtems-users at rtems.org
  Sent: Friday, March 14, 2008 6:21 PM
  Subject: LEON2 console ringbuf.h
  Hi all,
  I am trying to build an RTEMS for a LEON2 processor using the UART support (CONSOLE_USE_INTERRUPTS=1). The compilation fails when processing console.c because it can not find ringbuf.h.
  I have tried with rtems-4.7.99.2 and the prebuitl tools from Gaisler Research, and with the rtems-4.8 and a self made toolchain. Both of them work without problems without the UART support.
  cd b-leon2
  ../rtems-4.8.0/configure --target=sparc-rtmes --enable-rtemsbsp=leon2 --enable-test=samples --disable-itron --disable-posix CONSOLE_USE_INTERRUPTS=1
  make
  Any hint of what could I be missing?
  Jose
  rtems-users mailing list
  rtems-users at rtems.com
  http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20080315/61d45db8/attachment-0001.html>
