I want to participate in GSoC from RTEMS
Ralf Corsepius ralf.corsepius at rtems.org
Thu Mar 20 14:54:05 UTC 2008
On Thu, 2008-03-20 at 20:15 +0530, Madhusudan C.S wrote:
> Hi Joel,
>             I installed all the packages you said, I had actually
> installed CPU packages earlier. I now installed all the common
> packages. I then did a bootstrap again and ran configure in the same
> way you have given. There were no errors. But when I type make, I
> again get this errror
> configure: creating make/sis.cache
> make[3]: Entering directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis'
> make[3]: Leaving directory
> checking for RTEMS_CPU_MODEL... erc32
> checking for RTEMS_BSP_FAMILY... (cached) erc32
> checking for CPU_CFLAGS... (cached) -mcpu=cypress
> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
> checking for style of include used by make... GNU
> checking for sparc-rtems4.9-gcc... sparc-rtems4.9-gcc
> checking for sparc-rtems4.9-gcc... (cached) sparc-rtems4.9-gcc
> checking for C compiler default output file name...
> configure: error: C compiler cannot create executables
> See `config.log' for more details.
> make[2]: *** [sis] Error 1
> make[2]: Leaving directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [all-recursive] Error 1
Please do as configure tells you: "See 'config.log' for more details."
(In your case, it's probably
media/professional/rtems/b-sis/sparc-rtems4.9/c/config.log)
> what does this mean, "configure: error: C compiler cannot create
> executables"??
It means what it says: The compiler, the configure script is trying to
run (above: sparc-rtems4.9-gcc) "doesn't work".
The reasons for why it finds the compiler to "not working" are manifold.
config.log normally contains a log of the actual breakdown, which would
provide further hints on the cause.
Ralf
