Building 4.8 on OS X
Alan Cudmore Alan.P.Cudmore at nasa.gov
Wed Mar 26 23:50:16 UTC 2008
When you run the configure command for the RTEMS source, make sure
you specify powerpc-rtems4.8:
I use the script below to build RTEMS. It works on OS X.
Alan
#!/bin/bash
# Coldfire Development kit RTEMS build script version 2.0
# Alan Cudmore -- NASA/GSFC
# Enhancements copied from psptoolchain build script by:
# Dan Peori <peori at oopo.net>
# Settings: Directories, target architecture
SOURCE_DIR=/opt/coldfire-devkit-4/rtems-src
INSTALL_DIR=/opt/rtems-4.9
TARGET=m68k-rtems4.9
# Which version of RTEMS are we building?
RTEMS_VERSION=4.9-cvs
# RTEMS_VERSION=4.9
# configure, build and install RTEMS
rm -rf build-rtems
mkdir build-rtems
cd build-rtems
$SOURCE_DIR/rtems-$RTEMS_VERSION/configure --target=$TARGET --prefix=
$INSTALL_DIR --enable-posix --disable-itron --enable-networking --
enable-cxx || { echo "ERROR CONFIGURING RTEMS"; exit; }
make RTEMS_BSP="mcf5235" || { echo "ERROR BUILDING RTEMS"; exit; }
make RTEMS_BSP="mcf5235" install || { echo "ERROR INSTALLING RTEMS";
exit; }
cd ..
echo "Done!"
On Mar 26, 2008, at 7:27 PM, Nigel Spon wrote:
> Hi,
> I'm working on getting rtems 4.8.0 built for PowerPC under Mac OS
> 10.5, and making reasonable progress. I hope to make it work with
> Apples XCode IDE in due course, but at the moment I'm just trying to
> get the build process up by following the "Getting Started with RTEMS"
> documentation.
> I have (apparently) successfully built the cross-compiler and
> associated tools, and have set up the path to their /bin subdirectory.
> This now has a bunch of tools in it all prefixed with powerpc-
> rtems4.8. I have verified the toolset operation on a small file: I can
> do:
> powerpc-rtems4.8-gcc -v -S f.c
> and get appropriate responses. However I can't say:
> powerpc-rtems-gcc -v -S f.c
> which seems to make sense, because none of the tools are called that.
> The trouble is that if I try to build RTEMS it fails with:
> checking for powerpc-rtems-gcc... no
> configure: error: no acceptable cc found in $PATH
> ... which seems to indicate it is looking for powerpc-rtems-gcc, not
> powerpc-rtems4.8-gcc. What is the right way to fix this? Have I missed
> creating some link files somewhere, or do my tools need to be renamed
> with more generic names?
> Thanks for any assistance,
> "Where are those who in times past have opposed the Group of
> Seventeen?"
> Michael Hamel
> ADInstruments Ltd, Dunedin, NZ
> rtems-users mailing list
> rtems-users at rtems.com
