Google summer of code
    Ray
    rayx.cn at gmail.com
    Sat Mar 29 05:45:58 UTC 2008
Hi, Kliakhandler Kosta
Skyeye can run lpc22xx in latest version. However, for lpc21xx family, you will have sth more to do. There is also another BSP for lpc2148 in early mail thread (this bsp did not get into main trunk because the memory limitations).
BTW, To simulator the real hardware environment, you will have to tune the memory map in skyeye. And run tinyRTEMS in real hardware is also good idea.
As for the idea of tinyRTEMS, you may also add sth new like run-time footprint control, how to share memory, how keep systems from crash if memory alloc failed, how to tune the memory management systems for small footprint system (ecos and freeRTOS have multiple ways of alloc memory)…..
The time for apply GSoC is very limited now, you will have to hurry up.
Thanks & Best Regards!
Ray, rayx.cn at gmail.com
2008-03-29
----- Receiving the following content -----
Receiver:  Joel Sherrill
Time: 2008-03-29, 04:00:44
Subject: Re: Google summer of code
>   Thanks for your comments!
>   Quoting Joel Sherrill :
>> Kliakhandler Kosta wrote:
>>> Hello,
>>> I'm interested in working on RTEMS for Google summer of code. I'm
>>> particularly interested in working on tinyRTEMS and porting it to
>>> an lpc2138 board (which I posseess). I never used it (RTEMS), but
>>> I  am developing an application on the mentioned board and although
>>> I  didn't plan to use an rtos yet, the project will in general
>>> benefit  from it.
>> OK. There has been a lot of discussion on TinyRTEMS this week so I
>> am not going to repeat any of that.  It's Friday and I am tired. :)
>   I joined the list only a couple of days ago so I didn't see it, but
>I will definitely take a read it when I find the archives... (while
>writing this email I found it :)
>> Some suggestions.  You are proposing an lpc2138 BSP.  So I see
>> a few obvious tasks in your proposal:
>> + BSP for real hardware
>> + BSP runs on Skyeye simulator
>   AFAIK skyeye doesn't run lpc21xx yet - if so, that will probably be
>another task.. I haven't worked with skyeye either yet - Is there a
>significant difference (for rtems or otherwise) for code which runs on
>skyeye as opposed to code which runs on HW?
>> From a TinyRTEMS perspective, there are lots of ideas and you will have to
>> decide which tickle your fancy. How much memory is available on your
>> target hardware?
>   I'm thinking about what I want to do right now. I was hoping for
>some guidance about which features seemed most useful to the developers.
>> Do you have any display option?  If so, consider adding Microwindows/Nano-X
>> support to your proposal.
>   I have an lcd character screen - I don't know whether it qualifies
>as a "display", but I certainly will consider it.
>>> If possible, I would like some guidence regarding what is
>>> important, times, and general advice regarding writing a proposal
>>> for this project.
>> The student proposal deadline is approaching soon but you still have time
>> to make a proposal.  I think there are guidelines at the SOC site on what
>> outline to follow.  SOC has a schedule and your proposal should track that
>> with activities in stages that make sense based upon that.
>   I realized that - I meant it in an rtems centric way.. I realise
>that times for developing the various projects differ between
>developers, but I was hoping for some suggestions on the projects to
>take, so that my proposal wouldn't turn out unacheivable due to a
>massive amount of work on the one hand, or "unsatisfactory" because I
>proposed things which were too small... I guess what's left to do is
>to write a proposal and hope I'll have time to revise it according to
>suggestions...
>> Maybe one of the others can post some helpful links.
>>> Thanks in advance,
>>> Kosta.
>>> Kliakhandler Kosta.
>>> Website: http://www.kosta.tk
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v2.0.7 (GNU/Linux)
>iQEVAwUAR+1ObN+ayDnCMRpdAQJb8QgAojsX6hzB3vs2XCVziz1S8xLBVopBvRBw
>p5sTjs1dpkRseP3Th/3r8z7n+wTZXT8Dy0m3yc+Fdy29GTGszCSZ7frIInPNGgb4
>9WcolHdbCuYpxAlKdPrwfLKk6vbn8/eH3nHcUxA4XqDrQXNOrG8iMmWw9fKn+iaO
>sw1/VtUcfvbZ1IPy0+HuHtDOWxGrLj9onEBVf/sbQNTtk5WlHcfHCEfNyuVKI0Qx
>DM07TvGcJONnC9DgG0zA2LP9a4KdPqdYdKyFBv7SBjNC5/CBfzSUcKza+hwWyZ3j
>QEHJt9M8lbt5KK7mYfbcO6U6gEmmMLg/FACpLIa8UuOi1M+NZun7yg==
>=h0wM
>-----END PGP SIGNATURE-----
>-----BEGIN PGP PUBLIC KEY BLOCK-----
>mQGiBEYowxURBACkGYIgmjTkJg6tzohJk2rB+k1THhbeowSRjaAn3XeDai5gaHc9
>6WPnCIrmzEEleBjSywqQ9MqVeY8n7I26iXbNQ+N/W/AK0q21nTXFtl6kn40/m2M1
>HB9mQoqYElV8IXGOajM/NuiQVXkVQRwzsiNE9MX2OjQUMirIcFda3dxPzwCgvQZI
>JwzMHzQQwJj8lOpgMCOrFkcD/1J/375/7ZVZ20yPTJh5/TZtlA7u0jHEoXMCoS46
>1AfHwISZtAB2R2uk34+2LDIOO1g8Eoy0HsRfWaoVLhhiBebdehX6xCN860LrxV8x
>NqN/E4WQZXy1TybXnNHRJq+F8o0b2gKCMurN3DAd2ODzHK0BKb893VOzsPcqy0KX
>p30OA/wOf5RZK1c10a+xQ8AHvf7mmu7vlkYdfp1QIpNo6wdbHBvY9Q0Ke2f/FMS4
>cX3pkl0v0W20mukHrpFFwtNov8Mtu+bgKUIq1XjHyrOCgJIHd+F/3t1wafsTeV97
>fQD2Bs2fJs/Oaba1Xd8uhAhz58ZWXRCtz6H1xiQac7OGER40p7QqS2xpYWtoYW5k
>bGVyIEtvc3RhIDxLbGlha2hhbmRsZXJAa29zdGEudGs+iF8EExECACAFAkYowxUC
>GwMGCwkIBwMCBBUCCAMEFgIDAQIeAQIXgAAKCRBKPapBzRwTbUQlAJ0eX+fK+SQJ
>x2oSjlB2EKhCAz9LjwCY0LtiBGiKzKcqMMVxLISKG2jGjbkBDQRGKMMVAQgAxIyS
>WEOU+BuUQBTr8dt39aiXs9UFw5sdEQB5WGLgU3QU+0YZn3Q0c0Ie03JWIlMpU7RK
>EMxs5Ti2FQ4HRKhgw1q/cMEANpvgGVsUReHzhpCWuHOY3pK7EQuAsecDGiMwTaUT
>oFjWjxgqJQ5Hg8pFDyDutMfWBY1U8Jb7rF+s1z2nYDPAw8Psn8vPMEjjERn59K8i
>aPPtp482lt94Wgj6CR7eHSSik9PJmispuvLXQzKoEoKJVI8zKrSXf1oJesrCFp1C
>4GdeSHmuELBagqRP7Q5fiNpybaeEQfYSfgDi7SJNq5jrnwKozDbyCABIKS9/aPnH
>28q1hEdXEJhp1PZy8QARAQABiQFoBBgRAgAJBQJGKMMVAhsuASkJEEo9qkHNHBNt
>wF0gBBkBAgAGBQJGKMMVAAoJEN+ayDnCMRpd16kIAK3Q+A9OvRWjrYB11npqfHgd
>3Njmd6jCc1tMMYKT71UnHrI7BnFUOatwpAi5ZL2MMCm3HWW3bXb9hoX8K/++CsAQ
>fa0z5EufxZN9oI6poCGCn7zpFRdI+eT609nTZ0EODg8/2rOzD7uhZTZfebImwpqY
>UPtZDLShCH7LEydeUeLs610fYvs6Sm3ARrIFoJqdIaRz3hzyLB801irKdt7uch1j
>g2iWviNIbJBXr+fKvHzJ8ZSFcjf0z82Ta35Dio842gib/7hSs6FrmeKErCifs8Rn
>GOQRTJSJKv2aGECD2YTUTmeIwpB9mMmOjwJ3vG9w6sjPhK2bnnkMcwF3wgC7bstu
>kACgoH2cgzJtI1gPr5di3YAdHTOwvXcAoJz+ReQsiau6slovFawVTUFLfp4S
>=DDeg
>-----END PGP PUBLIC KEY BLOCK-----
>_____________________ next part ______________________
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
