Using RTEMS kernel on arm based board - bare bsp
Vinod Kulkarni vinodk at tataelxsi.co.in
Mon May 5 08:27:34 UTC 2008
Hi,
    I am using arm based board (PXA255 based). I have built RTEMS kernel
with bare bsp. I have my own boot-loader which is capable of loading the
kernel. Once I load the kernel I am getting a dot (.) as the output. Could
you please let me know whether this is the expected behavior?
Regards
Vinod
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments contained in it.
Contact your Administrator for further information.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080505/e1248c66/attachment.html>
