Using RTEMS kernel on arm based board - bare bsp
xu ray rayx.cn at gmail.com
Mon May 5 08:39:24 UTC 2008
It is not the expected behavior.
How about your serial port's setting, Rate/Nor/7bit.....
2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
>  Hi,
>     I am using arm based board (PXA255 based). I have built RTEMS kernel
> with bare bsp. I have my own boot-loader which is capable of loading the
> kernel. Once I load the kernel I am getting a dot (.) as the output. Could
> you please let me know whether this is the expected behavior?
> Regards
> Vinod
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s) and
> may contain proprietary, confidential or privileged information. If you are
> not the intended recipient, you should not disseminate, distribute or copy
> this e-mail. Please notify the sender immediately and destroy all copies of
> this message and any attachments contained in it. Contact your Administrator
> for further information.
> rtems-users mailing list
> rtems-users at rtems.com
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080505/8d9ccfb7/attachment-0001.html>
