Virtex SPI Driver
Robert S. Grimes
rsg at alum.mit.edu
Tue May 6 18:19:57 UTC 2008
Hi Thomas, et. al.
Well, I've got an implementation of the low-level SPI driver for Virtex
working, and am wondering what I should do with it wrt the RTEMS tree.
I've based it on RTEMS-4.8.0 tarball, with the newer libi2c code from
trunk several months ago. Because I am not proficient in the autoXXX
tools, I could not build it as part of the BSP, so on the advice of
others, I simply included it in my application library. So some work
would be needed to make it part of the Virtex BSP...
However, this brings up another issue that is peculiar to this type of
BSP; while my hardware is different from the Xilinx ml403 board you
used, the issue is the same. These boards consist of a very
configurable FPGA, combined with specific support components. While the
latter characteristic is equivalent to most boards (i.e. the hardware
present drives what the BSP supports), the reconfigurability of the
FPGA, along with the expansion headers, allow any specific instance to
contain a very varied mix of peripherals. For example, one of my
processors will use two serial ports and three SPI controllers, while
the other two only have a single serial port and two SPI controllers
each. I don't want to have multiple BSPs hanging around for myself, and
I certainly would not want to require users of the Virtex BSP to have an
SPI controller if they don't want it.
In getting around this issue for myself, I've changed the signature that
you used for registering the SPI bus; here is what I've come up with:
rtems_status_code spiRegisterBus(
char* busName, // Name for this bus
virtex_spi_desc_t* busDesc, // SPI descriptor for this bus
int numDevices, // Number of devices on
this SPI bus
virtex_spi_device_desc_t* devices); // List of devices on this
SPI bus
Now, this function could well be called by the BSP proper, if a board
was to always have a specific SPI bus and set of devices. But this
function can also be called by the application, which is what I'm doing;
this allows the BSP (and my common libraries) to support my several
applications.
What should I do to submit this code? I can't solve the build system
work that needs to be done, due to lack of knowledge and time...
Take care,
-Bob
