PowerPC exceptions and interrupts
Sebastian Huber
Sebastian.Huber at embedded-brains.de
Wed May 14 10:07:30 UTC 2008
Hi,
I adapted the shared exception and interrupt
(libcpu/powerpc/new-exceptions/*) code to work with the e200z6 and this
lead to some comments.
The current code implicitly defines BSP_SHARED_HANDLER_SUPPORT. I
modified it to support this preprocessor directive. Where is the right
place to define it?
Currently the shared interrupt handler support works like a stack. You
can push and pop a handler. But in BSP_remove_rtems_irq_handler is also
code that removes the handler from a list. What was intended?
The interrupt support code only ensures that interrupts are disabled
during critical sections. May it be useful to add a mutex to support
usage in multiple threads?
The BSP interrupt routines are declared in cpukit/include/rtems/irq.h
but don't follow the RTEMS naming conventions. A RTEMS interface for
interrupts would be nice?
I found no place where the entry isOn from rtems_irq_connect_data is
used. We may remove it.
The MPC5566 evaluation board has only 128kB internal RAM. Due to the 328
interrupt sources the interrupt handler table is quite big: 7896 Bytes
(6% of internal RAM). The exception handler table is also not very small
with 896 Bytes (0.7% of internal RAM). Thus I want to introduce two new
defines BSP_CONFIG_CONSTANT_EXCEPTION_TABLE and
BSP_CONFIG_CONSTANT_INTERRUPT_TABLE and modify the code to support
constant tables.
Regards,
Sebastian
embedded brains GmbH
Sebastian Huber Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-6
Fax : +49-89-18 90 80 79-9
email: Sebastian.Huber at embedded-brains.de
PGP public key available on request
