PowerPC exceptions and interrupts
Till Straumann
strauman at slac.stanford.edu
Wed May 14 15:27:47 UTC 2008
Sebastian Huber wrote:
> Hi,
> I adapted the shared exception and interrupt
> (libcpu/powerpc/new-exceptions/*) code to work with the e200z6 and this
> lead to some comments.
> The current code implicitly defines BSP_SHARED_HANDLER_SUPPORT. I
> modified it to support this preprocessor directive. Where is the right
> place to define it?
IMHO this symbol should go away altogether. Implementing
shared interrupts (more than 1 handler per IRQ) should be
mandatory. It doesn't consume a lot of resources; especially
if not used (the 'install' routine could be split into a separate
file so that it is not linked if unused).
The current situation is ugly -- if you don't include the file
where BSP_SHARED_HANDLER_SUPPORT is defined prior to
including rtems/irq.h then you don't get the correct declarations
IIRC.
> Currently the shared interrupt handler support works like a stack. You
> can push and pop a handler. But in BSP_remove_rtems_irq_handler is also
> code that removes the handler from a list. What was intended?
? I guess I don't understand this point. I don't know of any
routines (we're talking about new-execeptions/bspsupport/irq.c, right?)
to push/pop interrupts. BSP_install_rtems_shared_irq_handler
adds a handler at the head of the list of handlers,
BSP_remove_rtems_irq_handler extracts a handler from the list.
> The interrupt support code only ensures that interrupts are disabled
> during critical sections. May it be useful to add a mutex to support
> usage in multiple threads?
No. Protecting a critical section by disabling interrupts is
already thread-safe (and used in many places in RTEMS).
It might also be quicker/cheaper if it protects short sections
of code.
That said - I realize that interrupts were disabled across
malloc and free which is bad. I just fixed this.
> The BSP interrupt routines are declared in cpukit/include/rtems/irq.h
> but don't follow the RTEMS naming conventions. A RTEMS interface for
> interrupts would be nice?
Oh yes - and a less clumsy one. The existing rtems_interrupt_catch
would be great *if* it supported a user argument to the isr...
> I found no place where the entry isOn from rtems_irq_connect_data is
> used. We may remove it.
Unfortunately, this would break all existing applications which
use the current API. This is IMO not a good idea.
It would be better to come up with a new API, deprecate the old
one and phase it out eventually.
> The MPC5566 evaluation board has only 128kB internal RAM. Due to the 328
> interrupt sources the interrupt handler table is quite big: 7896 Bytes
> (6% of internal RAM). The exception handler table is also not very small
> with 896 Bytes (0.7% of internal RAM). Thus I want to introduce two new
> defines BSP_CONFIG_CONSTANT_EXCEPTION_TABLE and
> BSP_CONFIG_CONSTANT_INTERRUPT_TABLE and modify the code to support
> constant tables.
This defeats the whole 'new-exceptions' API which provides
methods to change raw exception handlers. Just playing
devil's advocate...
And how can a BSP with a constant interrupt table support
applications which use the calls to install/remove interrupt
handlers? You'd rather have to think of an alternative implementation
of the current API -- since probably most of the 328 sources
are unused e.g., a (smaller) hash table could be used and
the real 'rtems_irq_connect_data' structs be allocated only on demand.
In any case: prior to modifying code I suggest you make
proposals as to how the API must be changed and what
implementation you propose. Any implementation should
be generically useful rather than #ifdef dependent...
Cheers
-- Till
> Regards,
> Sebastian
> embedded brains GmbH
> Sebastian Huber Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-6
> Fax : +49-89-18 90 80 79-9
> email: Sebastian.Huber at embedded-brains.de
> PGP public key available on request
> rtems-users mailing list
> rtems-users at rtems.com
