Udp no buffer error
fall4ufeng
fall4ufeng at gmail.com
Mon May 26 08:16:31 UTC 2008
hi all:
I met "RTEMS:Can't send :No buffer space available" error when i test the UDP transmit.
I only tried to send 500 small packets.I added rtems_bsdnet_show_mbuf_stats() before the program exited,
and the output is as following:
************ MBUF STATISTICS ************
mbufs:1024 clusters: 128 free: 59
drops: 0 waits: 0 drains: 0
free:898 data:126 header:0 socket:0
pcb:0 rtable:0 htable:0 atable:0
soname:0 soopts:0 ftable:0 rights:0
ifaddr:0 control:0 oobdata:0
It can send packets successfully when i added sleep(1) between it trasnmit each packet.
Can someone give advices ? Thanks .
2008-05-26
fall4ufeng
URL: <http://lists.rtems.org/pipermail/users/attachments/20080526/79426568/attachment.html>
