Udp no buffer error
Ian Caddy
ianc at goanna.iinet.net.au
Mon May 26 09:14:12 UTC 2008
Hi,
Which BSP are you using? This doesn't look like you are running out of
mbufs, maybe it is a problem with your MAC driver?
Which version of RTEMS are you running?
regards,
Ian Caddy
fall4ufeng wrote:
> hi all:
> I met "RTEMS:Can't send :No buffer space available" error when i test
> the UDP transmit.
> I only tried to send 500 small packets.I added
> rtems_bsdnet_show_mbuf_stats() before the program exited,
> and the output is as following:
> ************ MBUF STATISTICS ************
> mbufs:1024 clusters: 128 free: 59
> drops: 0 waits: 0 drains: 0
> free:898 data:126 header:0 socket:0
> pcb:0 rtable:0 htable:0 atable:0
> soname:0 soopts:0 ftable:0 rights:0
> ifaddr:0 control:0 oobdata:0
> It can send packets successfully when i added sleep(1) between it
> trasnmit each packet.
> Can someone give advices ? Thanks .
> 2008-05-26
> fall4ufeng
> rtems-users mailing list
> rtems-users at rtems.com
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
