Using RTEMS kernel on arm based board - bare bsp
Vinod Kulkarni
vinodk at tataelxsi.co.in
Tue May 6 02:36:35 UTC 2008
Hi,
Even the kernel compiled with bare BSP would print that?
I have one more question. Which is the suitable BSP for PXA255 based board?
Regards
Vinod
-----Original Message-----
Sent: Mon 5/5/2008 4:37 PM
To: Vinod Kulkarni
Cc: rtems-users at rtems.com
Subject: Re: Using RTEMS kernel on arm based board - bare bsp
BSP by default will not out put anything.
You serial port should get:
*** HELLO WORLD TEST ***
Hello World
END OF HELLO WORLD TEST
press any key to restart
That is the same for all ARM ports, some BSP might output debug info when
loading driver. However, I believe yours does not. You might need to check
your console driver's code.
2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
> Hi,
> My serial port settings are:
> Baud - 115200
> Data - 8
> Stop - 1
> Parity - None
> Hardware flow control - None
> Software flow control - None
> Could you please tell me what is the expected behavior (I have loaded
> hello.exe file)?
> Regards
> Vinod
> *From:* xu ray [mailto:rayx.cn at gmail.com]
> *Sent:* Monday, May 05, 2008 2:09 PM
> *To:* vinodk at tataelxsi.co.in
> *Cc:* rtems-users at rtems.com
> *Subject:* Re: Using RTEMS kernel on arm based board - bare bsp
> It is not the expected behavior.
> How about your serial port's setting, Rate/Nor/7bit.....
> Hi,
> I am using arm based board (PXA255 based). I have built RTEMS kernel
> with bare bsp. I have my own boot-loader which is capable of loading the
> kernel. Once I load the kernel I am getting a dot (.) as the output. Could
> you please let me know whether this is the expected behavior?
> Regards
> Vinod
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s) and
> may contain proprietary, confidential or privileged information. If you are
> not the intended recipient, you should not disseminate, distribute or copy
> this e-mail. Please notify the sender immediately and destroy all copies of
> this message and any attachments contained in it. Contact your Administrator
> for further information.
> rtems-users mailing list
> Thanks & Best Regards!
> Ray, Xu
Ray, Xu
This message (including any attachment) is confidential and may be legally privileged. Access to this message by anyone other than the intended recipient(s) listed above is unauthorized. If you are not the intended recipient you are hereby notified that any disclosure, copying, or distribution of the message, or any action taken or omission of action by you in reliance upon it, is prohibited and may be unlawful. Please immediately notify the sender by reply e-mail and permanently delete all copies of the message if you have received this message in error.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080506/3900dee2/attachment-0001.html>
