Using RTEMS kernel on arm based board - bare bsp
xi yang
hiyangxi at gmail.com
Tue May 6 03:18:33 UTC 2008
On Tue, May 6, 2008 at 12:36 PM, Vinod Kulkarni <vinodk at tataelxsi.co.in> wrote:
> Hi,
> Even the kernel compiled with bare BSP would print that?
> I have one more question. Which is the suitable BSP for PXA255 based board?
Rrtems does not have PXA255 BSP, I will submit it in this month.
> Regards
> Vinod
> -----Original Message-----
> From: xu ray [mailto:rayx.cn at gmail.com]
> Sent: Mon 5/5/2008 4:37 PM
> To: Vinod Kulkarni
> Cc: rtems-users at rtems.com
> Subject: Re: Using RTEMS kernel on arm based board - bare bsp
> BSP by default will not out put anything.
> You serial port should get:
> *** HELLO WORLD TEST ***
> Hello World
> END OF HELLO WORLD TEST
> press any key to restart
> That is the same for all ARM ports, some BSP might output debug info when
> loading driver. However, I believe yours does not. You might need to check
> your console driver's code.
> 2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
> > Hi,
> > My serial port settings are:
> > Baud - 115200
> > Data - 8
> > Stop - 1
> > Parity - None
> > Hardware flow control - None
> > Software flow control - None
> > Could you please tell me what is the expected behavior (I have loaded
> > hello.exe file)?
> > Regards
> > Vinod
> > *From:* xu ray [mailto:rayx.cn at gmail.com]
> > *Sent:* Monday, May 05, 2008 2:09 PM
> > *To:* vinodk at tataelxsi.co.in
> > *Cc:* rtems-users at rtems.com
> > *Subject:* Re: Using RTEMS kernel on arm based board - bare bsp
> > It is not the expected behavior.
> > How about your serial port's setting, Rate/Nor/7bit.....
> > Hi,
> > I am using arm based board (PXA255 based). I have built RTEMS kernel
> > with bare bsp. I have my own boot-loader which is capable of loading the
> > kernel. Once I load the kernel I am getting a dot (.) as the output.
> Could
> > you please let me know whether this is the expected behavior?
> > Regards
> > Vinod
> > The information contained in this electronic message and any attachments
> > to this message are intended for the exclusive use of the addressee(s)
> and
> > may contain proprietary, confidential or privileged information. If you
> are
> > not the intended recipient, you should not disseminate, distribute or
> copy
> > this e-mail. Please notify the sender immediately and destroy all copies
> of
> > this message and any attachments contained in it. Contact your
> Administrator
> > for further information.
> > rtems-users mailing list
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> > Thanks & Best Regards!
> > Ray, Xu
> and
> are
> copy
> of
> Administrator
> Ray, Xu
> This message (including any attachment) is confidential and may be legally
> privileged. Access to this message by anyone other than the intended
> recipient(s) listed above is unauthorized. If you are not the intended
> recipient you are hereby notified that any disclosure, copying, or
> distribution of the message, or any action taken or omission of action by
> you in reliance upon it, is prohibited and may be unlawful. Please
> immediately notify the sender by reply e-mail and permanently delete all
> copies of the message if you have received this message in error.
