BSP for 405
Thomas Dörfler Thomas.Doerfler at imd-systems.de
Wed May 7 06:54:15 UTC 2008
Michael,
we appreciate having a modern PPC405 BSP in RTEMS, apart from the virtex
BSP which always will have a special role and treatment.
Apart from the hint Chris gave you, please feel free to contact me
whenever a question comes up concerning PPC BSP integration.
A BSP typically is dedicated to one board (or a group of similar
boards). Therefore the major test platform will be your physical board.
An additional test for the changes you made to general code will be to
build same additional PPC BSPs, just to check whether you inadvertedly
broke something for other derivates.
A reasonable list for additions PPC BSPs might be:
MVME5500 mpc8349eamds brs5l mcp750
wkr,
Thomas.
Chris Johns schrieb:
> Michael™ Hamel wrote:
>> Hello,
>> I have a basic BSP (called kilauea) for the PPC405GP/GPr/EX/EXr that
>> uses the new exceptions middleware and appears to work correctly on my
>> 405EXr hardware, so I am wondering what my next step should be. I have
>> only the console, timer, and clock drivers up, and I seem to be able
>> to run the test programs, or at least the random ten or so that I have
>> tried.
>> I have had to make a few changes outside of my BSP directory to
>> support the DCRs on the 405, which is getting classified as a Book E
>> CPU although it isn't quite. I am working on a network driver for the
>> onboard MAL/EMAC, but that will obviously take some time.
>> What further testing should I do, and when (and how) should I submit
>> the BSP for inclusion in rtems-cvs?
> Thank you for the BSP. The Wiki provides details on how to contribute to
> RTEMS. See:
>   http://www.rtems.org/wiki/index.php/Contributing
> Regards
> Chris
> rtems-users mailing list
> rtems-users at rtems.com
