GSOC:disable newlibc reentrancy
Thu May 8 13:27:20 UTC 2008
Ralf Corsepius wrote:
> On Thu, 2008-05-08 at 20:35 +0800, 阎淼 wrote:
>> 2008/5/8, Ralf Corsepius <ralf.corsepius at rtems.org>:
>>>>> On Thu, 2008-05-08 at 14:54 +0800, 阎淼 wrote:
>>>>>> Hi,
>>>>>> I am trying to disable newlibc.c reentrant support.
>>>>> Why do you want to do this?
>>>> That is one of the size reduction ideas of tiny rtems project.
>>> OK, in verbose: What you are doing is absurd. It means to cut-off rtems
>>> from newlib, turning all of newlib and the whole compiler unusable.
>>    What is your suggestion?  And if newlibc reentrant extensions are
>> not supposed to be an option,  why macro like
>> CONFIGURE_DISABLE_NEWLIB_REENTRANCY exists in confdefs.h ?
> Because somebody didn't switch on his brains.
> Switching off reentrancy means using a different ABI inside of RTEMS
> than the toolchain's libc.
No it doesn't.  It simply means that all threads share a
single reentrancy structure.  No calls break.
> It means abusing the toolchain for a different compiler target.
No it doesn't.  It is turning off a run-time feature.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
