GSOC:disable newlibc reentrancy
Ralf Corsepius
ralf.corsepius at rtems.org
Thu May 8 13:29:50 UTC 2008
On Thu, 2008-05-08 at 08:27 -0500, Joel Sherrill wrote:
> Ralf Corsepius wrote:
> > On Thu, 2008-05-08 at 20:35 +0800, 阎淼 wrote:
> >> 2008/5/8, Ralf Corsepius <ralf.corsepius at rtems.org>:
> >>>>> On Thu, 2008-05-08 at 14:54 +0800, 阎淼 wrote:
> >>>>>> Hi,
> >>>>>> I am trying to disable newlibc.c reentrant support.
> >>>>> Why do you want to do this?
> >>>> That is one of the size reduction ideas of tiny rtems project.
> >>> OK, in verbose: What you are doing is absurd. It means to cut-off rtems
> >>> from newlib, turning all of newlib and the whole compiler unusable.
> >> What is your suggestion? And if newlibc reentrant extensions are
> >> not supposed to be an option, why macro like
> >> CONFIGURE_DISABLE_NEWLIB_REENTRANCY exists in confdefs.h ?
> > Because somebody didn't switch on his brains.
> > Switching off reentrancy means using a different ABI inside of RTEMS
> > than the toolchain's libc.
> No it doesn't. It simply means that all threads share a
> single reentrancy structure. No calls break.
> > It means abusing the toolchain for a different compiler target.
> No it doesn't. It is turning off a run-time feature.
Not in gcc/newlib
Ralf
