A couple of BSP questions
Till Straumann
strauman at slac.stanford.edu
Wed May 14 22:34:42 UTC 2008
Michael Hamel wrote:
> Hi,
> I am making progress with a PPC405EX BSP and am trying to move code
> into a generic libcpu/powerpc/ppc4xx directory, but I'm not sure how
> to organise it. I have conditional sections that need to know whether
> a PPC405EX/EXr or a GP/GPr/CR is in use (e.g DCR values).
Can't these be made run-time tests?
> The libcpu
> code therefore needs to see a definition somewhere from the BSP, e.g
> PPC4XX_SUBTYPE that selects between these options. This could come
> from bsp.h, or it could go into the CPU_CFLAGS options in the .cfg
> file, which I see is what the virtex BSP does. I'm not sure what would
> be best practice?
> Second, I see that in ppc_exc_bspsupp.h, interrupt handlers are
> defined as:
> typedef int (*ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned int
> vector);
> What value should they return in the int?
They should return 0 if the exception has been 'handled'
and execution can be resumed normally. If they return
a negative value then the situation is escalated to the
'global' exception handler.
E.g., the handler dealing with external interrupts returns 0.
If your handler discovers a situation it can remedy it should
return 0, if it can't it returns -1 resulting in a panic
and register dump.
(I just added a comment explaining this to ppc_exc_bspsupp.h)
HTH + Thanks for the reminder...
-- Till
> Regards,
> "Not *another* shrubbery!"
> Michael Hamel
> ADInstruments Ltd, Dunedin, NZ
> rtems-users mailing list
> rtems-users at rtems.com
