Udp no buffer error
Ian Caddy
ianc at goanna.iinet.net.au
Tue May 27 00:53:57 UTC 2008
Hi,
Please reply to the list otherwise useful information could get lost for
others later.
Reply below:
fall4ufeng wrote:
> hi Ian:
> Thanks for your reply.
> My bsp is supported by others ,it based on leon2, and i am using
> RTEMS-4.6.6.
> The net driver i use came from the NIC's driver in freebsd.
I had a quick look through the RTEMS network code for 4.6 and could not
find the error that you described. It does look like it is coming from
your Ethernet driver code.
Have you checked there to see if you can find this debug printout. This
would give you more information to help narrow down the problem.
regards,
Ian Caddy
> *发件人:* Ian Caddy
> *发送时间:* 2008-05-26 17:14:30
> *收件人:* fall4ufeng
> *抄送:* rtems-users at rtems.com.
> *主题:* Re: Udp no buffer error
> Hi,
> Which BSP are you using? This doesn't look like you are running out of
> mbufs, maybe it is a problem with your MAC driver?
> Which version of RTEMS are you running?
> regards,
> Ian Caddy
> fall4ufeng wrote:
> > hi all:
> > I met "RTEMS:Can't send :No buffer space available" error when i test
> > the UDP transmit.
> > I only tried to send 500 small packets.I added
> > rtems_bsdnet_show_mbuf_stats() before the program exited,
> > and the output is as following:
> > ************ MBUF STATISTICS ************
> > mbufs:1024 clusters: 128 free: 59
> > drops: 0 waits: 0 drains: 0
> > free:898 data:126 header:0 socket:0
> > pcb:0 rtable:0 htable:0 atable:0
> > soname:0 soopts:0 ftable:0 rights:0
> > ifaddr:0 control:0 oobdata:0
> > It can send packets successfully when i added sleep(1) between it
> > trasnmit each packet.
> > Can someone give advices ? Thanks .
> > 2008-05-26
> > fall4ufeng
> > rtems-users mailing list
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> Ian Caddy
> Goanna Technologies Pty Ltd
> +61 8 9444 2634
Ian Caddy
+61 8 9444 2634
