math lib inclusion
Fri Nov 7 15:54:53 UTC 2008
Neil Mayes wrote:
> Hi all,
> I am trying to get an application running that uses math.h. I understand
> I need to supply the math lib which is achieved by adding '-lm' to the
> library list.
> I am using RTEMS4.8.0 and gcc4.2.2 for the sparc (ERC32). I have based
> my application make file from an RTEMS example where there is the line:
> # Libraries
> LIBS = -lrtemsall -lc
Those are unfortunately relics in these old application
Makefiles and aren't even needed since there is no rtemsall
library and libc is implicit.  I don't think they
do anything.
Try
*LD_LIBS  += -lm
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> Should I just be able to add -lm to LIBS?
> Do I have to build the math library seperately from gcc and newlib for
> the sparc?
> Thanks,
> Neil Mayes
> rtems-users mailing list
> rtems-users at rtems.com
