math lib inclusion
Neil Mayes N.Mayes at sstl.co.uk
Fri Nov 7 16:02:03 UTC 2008
All works, many thanks.
Is there a better application makefile template to use?
Regards,
Neil
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 07 November 2008 15:55
> To: Neil Mayes
> Cc: rtems-users at rtems.org
> Subject: Re: math lib inclusion
> Neil Mayes wrote:
> > Hi all,
> > I am trying to get an application running that uses math.h. I
> > understand I need to supply the math lib which is achieved
> by adding
> > '-lm' to the library list.
> > I am using RTEMS4.8.0 and gcc4.2.2 for the sparc (ERC32). I
> have based
> > my application make file from an RTEMS example where there
> is the line:
> > # Libraries
> > LIBS = -lrtemsall -lc
> Those are unfortunately relics in these old application
> Makefiles and aren't even needed since there is no rtemsall
> library and libc is implicit.  I don't think they do anything.
> Try
> *LD_LIBS  += -lm
> > include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> > Should I just be able to add -lm to LIBS?
> > Do I have to build the math library seperately from gcc and
> newlib for
> > the sparc?
> > Thanks,
> > Neil Mayes
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
