plugin first steps
Ralf Corsepius ralf.corsepius at rtems.org
Wed Nov 26 03:47:51 UTC 2008
On Wed, 2008-11-26 at 09:56 +1100, Chris Johns wrote:
> Sebastian Huber wrote:
> > Chris Johns wrote:
> >> Joel Sherrill wrote:
> >>> It seems like you are working to extract information
> >>> from the RTEMS Application Makefiles and generate
> >>> some configuration information for Eclipse.  Chris
> >>> has been working to eliminate them in favor of autoconf
> >>> for the external examples.
> >> I have not followed in detail where they are getting the info from but
> >> Makefiles would concern me.
> > With from Makefiles I mean run make with a special Makefile and parse
> > the output of the make run.
> Sorry I do not know what this means.
I guess he is talking about converting *.cfg etc. into a different
format by running make. Essentially the same approach as I use to
extract *.cfgs in c/src/configure.ac and c/src/Makefile.am
(check for make.bsp and make.cache).
As you likely know, I consider this to be a blatant hack to work around
the ugliness RTEMS had inherited from the past. The *.cfgs and the
Makefile-templates are crap.
Ralf
