plugin first steps
Fri Nov 28 12:37:41 UTC 2008
Ralf Corsepius wrote:
> On Wed, 2008-11-26 at 09:56 +1100, Chris Johns wrote:
>> Sebastian Huber wrote:
>>> Chris Johns wrote:
>>>> Joel Sherrill wrote:
>>>>> It seems like you are working to extract information
>>>>> from the RTEMS Application Makefiles and generate
>>>>> some configuration information for Eclipse.  Chris
>>>>> has been working to eliminate them in favor of autoconf
>>>>> for the external examples.
>>>> I have not followed in detail where they are getting the info from but
>>>> Makefiles would concern me.
>>> With from Makefiles I mean run make with a special Makefile and parse
>>> the output of the make run.
>> Sorry I do not know what this means.
> I guess he is talking about converting *.cfg etc. into a different
> format by running make. Essentially the same approach as I use to
> extract *.cfgs in c/src/configure.ac and c/src/Makefile.am
> (check for make.bsp and make.cache).
> As you likely know, I consider this to be a blatant hack to work around
> the ugliness RTEMS had inherited from the past. The *.cfgs and the
> Makefile-templates are crap.
Yes, that is right.  I want to use this Makefile:
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
all:
	@echo CPP
	@for i in $(CPP) ; do printf "\t%s\n" "$$i" ; done
	@echo AS
	@for i in $(AS) ; do printf "\t%s\n" "$$i" ; done
	@echo COMPILE.c
	@for i in $(COMPILE.c) ; do printf "\t%s\n" "$$i" ; done
	@echo COMPILE.cc
	@for i in $(COMPILE.cc) ; do printf "\t%s\n" "$$i" ; done
	@echo LINK.c
	@for i in $(LINK.c) ; do printf "\t%s\n" "$$i" ; done
	@echo LINK.cc
	@for i in $(LINK.cc) ; do printf "\t%s\n" "$$i" ; done
The RTEMS_MAKEFILE_PATH is provided by the plug-in properties.  Every
time the user changes the project properties make will be invoked with
this Makefile.  The output of this process will be parsed and the
obtained options will be propagated to the corresponding tool
configuration as a built-in values.
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
