RTEMS for bare-bones ARM
Web.POP Marc.Enzmann at web.de
Wed Nov 26 21:17:59 UTC 2008
Hi All!
I am currently trying to get a version of RTEMS for ARM processors to
compile.
Following the instructions from
http://ww.rtems.com/wiki/index.php/RTEMSAda
Everything seems to go fine until I try to compile the Ada Cross-
Compiler. When making
adalib, the compilation stops, giving the following reason:
.../newlib/libc/include/sys/dirent.h:10:2: error: #error "<dirent.h>
not supported"
It would seem, that the Ada Runtime is a difficult beast.... :-)
Is there a way to tell make not to try to generate a file-system? How
do I select
the capabilities I need in the run-time?
Thanks in advance,
Marc
