c++ blackfin toolchain
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 18 14:36:30 UTC 2008
MOLM wrote:
> I have just installed toolchain and rtems 4.9 for the bf537 stamp
> board, and are able to compile the "hello world" sample - great!
> However, is there a reason for the g++ toolchain is missing for the
> blackfin architecture? Is it possible to build this support from
> source? I am trying to move a C++ application from uClinux environment
> to rterms in order to improve realtime response.
Ralf should recall if there is a current reason but historically the
bfin gcc port didn't build for bfin reliably and C++ rarely built.
Ralf have you checked this recently? Maybe things have improved.
You can always build your own toolchain and enable C++.
> Mads-l
