c++ blackfin toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Tue Nov 18 15:09:17 UTC 2008
On Tue, 2008-11-18 at 08:36 -0600, Joel Sherrill wrote:
> MOLM wrote:
> > I have just installed toolchain and rtems 4.9 for the bf537 stamp
> > board, and are able to compile the "hello world" sample - great!
> > However, is there a reason for the g++ toolchain is missing for the
> > blackfin architecture? Is it possible to build this support from
> > source? I am trying to move a C++ application from uClinux environment
> > to rterms in order to improve realtime response.
> Ralf should recall if there is a current reason but historically the
> bfin gcc port didn't build for bfin reliably and C++ rarely built.
Pardon, but I don't recall the details. IIRC, it had been a mixture of
"bugs" and "not being supported in GCC" (One detail I recall: issues
with libssp).
> Ralf have you checked this recently?
No. TBD.
>   Maybe things have improved.
> You can always build your own toolchain and enable C++.
Unless GCC rejects a language ;)
Ralf
