plugin first steps
Daron Chabot
daronchabot at gmail.com
Tue Nov 25 01:46:39 UTC 2008
On 24-Nov-08, at 6:17 PM, Chris Johns wrote:
> Joel Sherrill wrote:
>> It seems like you are working to extract information
>> from the RTEMS Application Makefiles and generate
>> some configuration information for Eclipse. Chris
>> has been working to eliminate them in favor of autoconf
>> for the external examples.
> I have not followed in detail where they are getting the info from
> but Makefiles would concern me.
I would prefer NOT to have to parse Makefiles too :-)
> The approach taken in the autoconf examples is to use the BSP
> configuration files.
> Does Eclipse have support for autotools ?
AFAIK, not yet... However it's a trivial matter to set up an External
Tool Launcher to run "configure". I do this when I use Eclipse to
build RTEMS.
>> Couldn't the same information be directly generated
>> by RTEMS?
> It is held in RTEMS already in the BSP config files. This file is
> installed when the BSP is installed.
Which file(s) are you referring to ? ${RTEMS_MAKEFILE_PATH}/
Makefile.inc ??
-- dc
