plugin first steps
Tue Nov 25 22:06:20 UTC 2008
Daron Chabot wrote:
> Which file(s) are you referring to ?
> ${RTEMS_MAKEFILE_PATH}/Makefile.inc ??
I do not use RTEMS_MAKEFILE_PATH or related variables and do not use any
environment variables so I am not sure about this path. The files are the ones
installed with RTEMS for a BSP. For example:
  /opt/rtems-4.9/make/custom/pc386.cfg
for RTEMS built with:
  configure --target=i386-rtems4.9 --enable-rtemsbsp=pc586
Regards
