plugin first steps
Sebastian Huber
Tue Nov 25 07:15:01 UTC 2008
Chris Johns wrote:
> Joel Sherrill wrote:
>> It seems like you are working to extract information
>> from the RTEMS Application Makefiles and generate
>> some configuration information for Eclipse. Chris
>> has been working to eliminate them in favor of autoconf
>> for the external examples.
> I have not followed in detail where they are getting the info from but
> Makefiles would concern me.
With from Makefiles I mean run make with a special Makefile and parse
the output of the make run.
> The approach taken in the autoconf examples is to use the BSP
> configuration files.
> Does Eclipse have support for autotools ?
Yes, there exists a CDT based Autotools plug-in, but the managed make
system from CDT is for our purpose much better.
>> Couldn't the same information be directly generated
>> by RTEMS?
> It is held in RTEMS already in the BSP config files. This file is
> installed when the BSP is installed.
Yes, but it is hard to extract information from these scattered files.
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
