EPICS on RTEMS 4.9 (for mvme2100 and mpc8313erdb)
Phillip Sorensen pas37 at cornell.edu
Thu Oct 2 15:49:00 UTC 2008
> /opt/rtems-4.9/bin/powerpc-rtems4.9-gcc --pipe
> -B/opt/rtems-4.9/powerpc-rtems4.9/mvme2100/lib/ -specs bsp_specs
> -qrtems   -fasm -c   -mcpu=603e -Dmpc603e -Dppc603e
> -DUNIX    -ansi  -O2 -g -mmultiple -mstring -mstrict-align -g
> -Wall      -DMY_DO_BOOTP=NULL -DHAVE_PPCBUG
> -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov <http://aps.anl.gov/>
> -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
> -I../../../src/libCom/env -I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
> -I../../../src/libCom/gpHash -I../../../src/libCom/logClient
> -I../../../src/libCom/macLib -I../../../src/libCom/misc
> -I../../../src/libCom/osi -I../../../src/libCom/taskwd
> -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
> -I../../../include/os/RTEMS -I../../../include
> ../../../src/libCom/bucketLib/bucketLib.c
> powerpc-rtems4.9-gcc: error trying to exec 'cc1': execvp: No such file
> or directory
> as: unrecognized option `-mppc'
I have been seeing basically the same error with the m68k tools trying
to compile EPICS base 3.14.9.  If I add the directory with cc1 to the
the path it seems to work.  I never had to do that with previous
versions of RTEMS.
I was able yesterday to compile EPICS base 3.14.10-RC1 without a
problem.  I have not looked for the difference yet.
