Point to sample SPI for MMC card driver?
Gene Smith gds at chartertn.net
Wed Oct 15 17:57:02 UTC 2008
I noticed that Robert S. Grimes seems to have finished his SPI driver
and he started with something in vertex BSP. The threads he started have
a lot of good information in them. Also, the README_libi2c is probably
the best and most thorough I have seen in RTEMS.
I am looking for some code to use as a starting point for writing my SPI
driver, which does not correspond to any existing BSP. I see that often
the SPI driver is divided between libcpu and libbsp. However, I probably
would want to put all the low level stuff in just my libbsp if possible.
I found something under libbsp/m68k/gen68360/spi that appears to be the
complete driver(s) (files m360_spi.c and mc68360_spidrv.c). Would these
be OK to use as a template? Or should I look somewhere else for a better
example?
Thanks,
-gene
