Does RTEMS really support client DHCP?
Gene Smith
gds at chartertn.net
Tue Oct 28 06:58:39 UTC 2008
How do you enable DHCP client support in RTEMS? In networkconfig.h you
define RTEMS_USE_BOOTP to enable BOOTP/DHCP. But when this happens I
only see BOOTP request broadcasts sent from the RTEMS unit, but get no
answer. When I plug in my other device, Macraigor JTAG described below,
I see packets DHCP Discover and DHCP Request and the address (and
hostname) are obtained. (This is looking with Wireshark.)
I see a large file, *dhcp.c, in RTEMS libnetworking but it is not
included in my code for some reason. Also, see references on the list to
BOOTP not working with Linksys routers and/or dnsmasq. So probably need
DHCP to work if possible. My wireless router is Linksys and it contains
dnsmasq.
My previous post on this subject is included below since it was a reply
to a very old post which may not be visible in threaded view mode.
Should have made a new post.
-gene
gene wrote 10/28/2008:
> The question below was asked on the list some time ago but never got a
> reply. I have also been trying to figure out the same question.
> Right now I have a non-RTEMS Macraigor jtag debugger box on my local
> network. I have given it a hostname "mpdemon" since that is what the
> product is. The host name is originally entered through the serial
> console on the jtag box. I have also configured the jtag box to obtain
> its IP address with DHCP (static is the other option). When the box
> powers up it obtains its address from my server (as I would expect) and
> it is ping-able and it webpage is accessible using the name mpdemon (or
> the longer name mpdemon.mylocaldomain). My DNS server (dnsmasq) was
> never told about the name "mpdemon" but now understands it when used by
> any host.
> As the question below points out, in RTEMS networkconfig.h you can't
> seem to specify the hostname when BOOTP (really DHCP?) is enabled. So is
> it possible to do in RTEMS what the Macraigor jtag box can do using DHCP
> (automatically make its hostname known in DNS)?
> -gene
> Alex Holeczy wrote, On 06/03/2005 09:42 AM:
>> > I am working on an RTEMS application where I am configuring the network
>> > interface to use BOOTP/DHCP to get the IP address for the system.
>> > In order for a user application to connect to the system, I would like
>> > to specify the network hostname of the system and I would prefer not
>> > having to configure the DHCP daemon with this information. This would
>> > allow the user application to connect to the system without knowing the
>> > IP or mac address.
>> > In the network configuration structure, there is an entry for the RTEMS
>> > application to provide a hostname. It seems that this hostname is only
>> > used locally and does not get included in the bootp request packet.
>> > Is there currently a way for an RTEMS application to provide the DNS
>> > server with its local hostname?
>> > What would be the downsize of modifying the bootp request packet to
>> > include the host name option?
>> > Regards,
>> > Alex
