Does RTEMS really support client DHCP?
Tim Cussins timcussins at eml.cc
Tue Oct 28 09:27:07 UTC 2008
Hi
One things I found with several routers is that the total reply length
was less than 300 bytes - this is valid for DHCP, but BOOTP requires at
least 300 bytes.
The RTEMS BOOTP implementation ignores any response less than 300 bytes,
last I looked. Might be a lead on your linksys problem.
HTH,
Tim
On Tue, 2008-10-28 at 02:58 -0400, Gene Smith wrote:
> How do you enable DHCP client support in RTEMS? In networkconfig.h you
> define RTEMS_USE_BOOTP to enable BOOTP/DHCP. But when this happens I
> only see BOOTP request broadcasts sent from the RTEMS unit, but get no
> answer. When I plug in my other device, Macraigor JTAG described below,
> I see packets DHCP Discover and DHCP Request and the address (and
> hostname) are obtained. (This is looking with Wireshark.)
> I see a large file, *dhcp.c, in RTEMS libnetworking but it is not
> included in my code for some reason. Also, see references on the list to
> BOOTP not working with Linksys routers and/or dnsmasq. So probably need
> DHCP to work if possible. My wireless router is Linksys and it contains
> dnsmasq.
> My previous post on this subject is included below since it was a reply
> to a very old post which may not be visible in threaded view mode.
> Should have made a new post.
> -gene
> gene wrote 10/28/2008:
> > The question below was asked on the list some time ago but never got a
> > reply. I have also been trying to figure out the same question.
> > Right now I have a non-RTEMS Macraigor jtag debugger box on my local
> > network. I have given it a hostname "mpdemon" since that is what the
> > product is. The host name is originally entered through the serial
> > console on the jtag box. I have also configured the jtag box to obtain
> > its IP address with DHCP (static is the other option). When the box
> > powers up it obtains its address from my server (as I would expect) and
> > it is ping-able and it webpage is accessible using the name mpdemon (or
> > the longer name mpdemon.mylocaldomain). My DNS server (dnsmasq) was
> > never told about the name "mpdemon" but now understands it when used by
> > any host.
> > As the question below points out, in RTEMS networkconfig.h you can't
> > seem to specify the hostname when BOOTP (really DHCP?) is enabled. So is
> > it possible to do in RTEMS what the Macraigor jtag box can do using DHCP
> > (automatically make its hostname known in DNS)?
> > -gene
> > Alex Holeczy wrote, On 06/03/2005 09:42 AM:
> >> > I am working on an RTEMS application where I am configuring the network
> >> > interface to use BOOTP/DHCP to get the IP address for the system.
> >> > In order for a user application to connect to the system, I would like
> >> > to specify the network hostname of the system and I would prefer not
> >> > having to configure the DHCP daemon with this information.  This would
> >> > allow the user application to connect to the system without knowing the
> >> > IP or mac address.
> >> > In the network configuration structure, there is an entry for the RTEMS
> >> > application to provide a hostname.  It seems that this hostname is only
> >> > used locally and does not get included in the bootp request packet.
> >> > Is there currently a way for an RTEMS application to provide the DNS
> >> > server with its local hostname?
> >> > What would be the downsize of modifying the bootp request packet to
> >> > include the host name option?
> >> > Regards,
> >> > Alex
> rtems-users mailing list
> rtems-users at rtems.com
