Interesting SD Card experiment with dosfs driver
Robert S. Grimes
rsg at alum.mit.edu
Wed Oct 29 21:15:44 UTC 2008
This is probably not terribly useful, I found it interesting. I'm not
reporting a problem here; rather, this is more of an example of how the
dosfs file-system works on top of the spi-sd-card driver.
My simple test is with a (mostly) empty SD card. I write 1 MByte of
data, in 32 chunks. Each chunk consists of 4 calls to write(), each of
8,192 bytes. Then, I close the file and unmount the partition.
To get a bit of insight, I print out a string like this on entry to the
spi-sd-card.c driver:
ReadN @ $0001F800
or of course, WriteN. In both cases, N is replaced by the number of SD
card "blocks" (512 bytes) to read or write.
Here is some (edited) output for this experiment.
First, I create the file - seems the driver reads 32 blocks (from the FAT?).
Creating tst4.txt, returned 4
Write1 @ $00060200
Write1 @ $00064200
Now I begin the four 8,192 byte write()
Writing 1 MBytes
BufferSize: 8192
Chunk 0 <== First chunk starts here
Read64 @ $0001F800
Read1 @ $0001FA00
Read1 @ $0001FC00
<snip> <== 28 other calls to Read1
Read1 @ $00023600
Note that the reads, other than the first, are all for consecutive
single blocks. Did the Read64 not work? Or are the subsequent Read1's
redundant?
Now comes the next 15 "chunks" of 32,768 bytes at the application level
Chunk 1
Chunk 2
<snip> <== 12 other chunks here
Chunk 15
Now comes 32 single, consecutive, block writes
Write1 @ $08264200
Write1 @ $08264400
<snip> <== 28 other writes here
Write1 @ $08267E00
Write1 @ $08268000
This pattern of a number of chunks (4 writes of 8192 from the
application), followed by the driver writing some number of single,
consecutive blocks. Here is what I observed:
Chunk 16
Write1 @ $08268200
<snip> <== 62 others
Write1 @ $08270000
Chunk 17
Write1 @ $08270200
<snip> <== 924 others
Write1 @ $082E3C00
Chunk 18
<snip> <== 13 other chunks here
Chunk 32
Write1 @ $082E3E00
<snip> <== 30 others
Write1 @ $082E7C00
Read1 @ $00060200 <== What is this for?
Done writing <== Message from application indicating
last write() has returned
Unmounting SD card <== Here is the call to unmount the card
Now, it gets interesting: first, there are 64 block writes, followed by
2 writes that do not appear to be part of the file, followed by 926 more
blocks,
Write1 @ $082E7E00
Write1 @ $082EFC00
Write1 @ $00023600 <== What are these...
Write1 @ $00041C00 <== two writes for?
Write1 @ $082EFE00
Write1 @ $08363800
Done! <== unmount() donw
Tests done - reboot now <== Application enters infinite loop here
Now, the application simple idles, but there are five more writes:
Write1 @ $00060200 <== Directory update?
Write1 @ $08363A00 <== Final four blocks of file!
Write1 @ $08363C00
Write1 @ $08363E00
Write1 @ $08364000
Note that all the "Write1" messages with addresses 0x08XXXXXX add up to
2048 blocks of 512 bytes, or the expected 1 megabyte.
Notice that the last five writes occur after the unmount() call returns,
which is a bit scary - I would have thought that it would be save to
shutdown immediately after it returned.
Other than those two writes in the middle to locations I don't
understand, this seems to make sense. It also means that, if it really
is true that pre-erased blocks write more quickly without software
assistance, then preparing a card by erasing first will help
applications like mine!
Hope I haven't bored you all too much on this!
-Bob
