UDP test problem
朱旭峰
fall4ufeng at gmail.com
Wed Oct 29 16:48:19 UTC 2008
hi all:
I write a driver for a network adapter , and I used netdemo to test
the driver. It can ping , telnet and transmit TCP packets successfully,but I
met
a problem when I used it to transmit UDP packets.
When I first typed the 'u' command in the console after netdemo got
run, it can only transmit *one* UDP packet( after it transmit 5 UDP
broadcast packets and an ARP packet ), and then I typed the 'u' command
again, now it can transmit the UDP packets successfully.
So, any one can give some advices ?Thanks a lot.
URL: <http://lists.rtems.org/pipermail/users/attachments/20081030/7df20ce0/attachment.html>
