Does RTEMS really support client DHCP? [YES!]
Gene Smith
gds at chartertn.net
Wed Oct 29 18:01:29 UTC 2008
Yes, pretty simple (but undocumented AFAICT).
Just define RTEMS_USE_BOOTP in application file networkconfig.h and
change rtems_bsd_do_bootp to rtems_bsd_do_dhcp in the
rtems_bsdnet_config definition. You also have to declare "void
rtems_bsdnet_do_dhcp (void);" in networkconfig.h and it works.
You can also specify a hostname in rtems_bsdnet_config and move it
outside of #if (!defined (RTEMS_USE_BOOTP)) and the hostname works like
the Macraigor device described below, e.g., you can ping using your
hostname or the hostname plus domain name (domain name current set in
DNS/DHCP server, e.g., dnsmasq.conf).
I need to go back and make sure bootp also works, but I mainly wanted
DHCP. (Not sure about the possibly bootp issue with dnsmasq.)
Gene Smith wrote:
> How do you enable DHCP client support in RTEMS? In networkconfig.h you
> define RTEMS_USE_BOOTP to enable BOOTP/DHCP. But when this happens I
> only see BOOTP request broadcasts sent from the RTEMS unit, but get no
> answer. When I plug in my other device, Macraigor JTAG described below,
> I see packets DHCP Discover and DHCP Request and the address (and
> hostname) are obtained. (This is looking with Wireshark.)
> I see a large file, *dhcp.c, in RTEMS libnetworking but it is not
> included in my code for some reason. Also, see references on the list to
> BOOTP not working with Linksys routers and/or dnsmasq. So probably need
> DHCP to work if possible. My wireless router is Linksys and it contains
> dnsmasq.
> My previous post on this subject is included below since it was a reply
> to a very old post which may not be visible in threaded view mode.
> Should have made a new post.
> -gene
> gene wrote 10/28/2008:
>> The question below was asked on the list some time ago but never got a
>> reply. I have also been trying to figure out the same question.
>> Right now I have a non-RTEMS Macraigor jtag debugger box on my local
>> network. I have given it a hostname "mpdemon" since that is what the
>> product is. The host name is originally entered through the serial
>> console on the jtag box. I have also configured the jtag box to obtain
>> its IP address with DHCP (static is the other option). When the box
>> powers up it obtains its address from my server (as I would expect) and
>> it is ping-able and it webpage is accessible using the name mpdemon (or
>> the longer name mpdemon.mylocaldomain). My DNS server (dnsmasq) was
>> never told about the name "mpdemon" but now understands it when used by
>> any host.
>> As the question below points out, in RTEMS networkconfig.h you can't
>> seem to specify the hostname when BOOTP (really DHCP?) is enabled. So is
>> it possible to do in RTEMS what the Macraigor jtag box can do using DHCP
>> (automatically make its hostname known in DNS)?
>> -gene
>> Alex Holeczy wrote, On 06/03/2005 09:42 AM:
>>>> I am working on an RTEMS application where I am configuring the network
>>>> interface to use BOOTP/DHCP to get the IP address for the system.
>>>> In order for a user application to connect to the system, I would like
>>>> to specify the network hostname of the system and I would prefer not
>>>> having to configure the DHCP daemon with this information. This would
>>>> allow the user application to connect to the system without knowing the
>>>> IP or mac address.
>>>> In the network configuration structure, there is an entry for the RTEMS
>>>> application to provide a hostname. It seems that this hostname is only
>>>> used locally and does not get included in the bootp request packet.
>>>> Is there currently a way for an RTEMS application to provide the DNS
>>>> server with its local hostname?
>>>> What would be the downsize of modifying the bootp request packet to
>>>> include the host name option?
>>>> Regards,
>>>> Alex
