Ubuntu Tool-Building Blues
Robert S. Grimes
rsg at alum.mit.edu
Fri Sep 12 23:34:13 UTC 2008
I'm trying to set up a build environment for testing the 4.9 branch on
Ubuntu Linux, and I'm having a few problems.
1. I had hoped to use the prebuilt RPMs, but it seems Ubuntu is not
supported :-( . So I must build them myself, right?
2. Because I've been using 4.8, and need to update to use Sebastian's
spi-sd-card driver - as well as possibly the nvdisk with FRAM), and am
thinking of the future, I thought I'd try to build the 4.10 tools in
/ftp/pub/rtems/SOURCES/4.10 - is that a good idea, or should I use 4.9?
3. I got binutils-2.18.tar.bz2, unpacked and patched it, confugiured a
build directory, and am trying to build. It failed, suggesting I
install texinfo (though that was just a warning). After installing
texinfo, it still fails at the same place, and I can't seem to see the
error. Here is the complete output:
rsg at vir:~/rtems/tools/b-binutils$ make all
make[1]: Entering directory `/home/rsg/rtems/tools/b-binutils'
make[2]: Entering directory `/home/rsg/rtems/tools/b-binutils/libiberty'
make[3]: Entering directory
`/home/rsg/rtems/tools/b-binutils/libiberty/testsuite'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory
make[2]: Leaving directory `/home/rsg/rtems/tools/b-binutils/libiberty'
make[2]: Entering directory `/home/rsg/rtems/tools/b-binutils/intl'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/rsg/rtems/tools/b-binutils/intl'
make[2]: Entering directory `/home/rsg/rtems/tools/b-binutils/bfd'
Making info in doc
make[3]: Entering directory `/home/rsg/rtems/tools/b-binutils/bfd/doc'
restore=: && backupdir=".am$$" && \
rm -rf $backupdir && mkdir $backupdir && \
if (/home/rsg/rtems/tools/binutils-2.18/missing makeinfo
--split-size=5000000 --split-size=5000000 --version) >/dev/null 2>&1; then \
for f in bfd.info bfd.info-[0-9] bfd.info-[0-9][0-9] bfd.i[0-9]
bfd.i[0-9][0-9]; do \
if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
else :; fi && \
if /home/rsg/rtems/tools/binutils-2.18/missing makeinfo
--split-size=5000000 --split-size=5000000 -I
../../../binutils-2.18/bfd/doc \
-o bfd.info `test -f 'bfd.texinfo' || echo
'../../../binutils-2.18/bfd/doc/'`bfd.texinfo; \
then \
rc=0; \
else \
rc=$?; \
$restore $backupdir/* `echo "./bfd.info" | sed 's|[^/]*$||'`; \
fi; \
rm -rf $backupdir; exit $rc
WARNING: `makeinfo' is missing on your system. You should only need it if
you modified a `.texi' or `.texinfo' file, or any other file
indirectly affecting the aspect of the manual. The spurious
call might also be the consequence of using a buggy `make' (AIX,
DU, IRIX). You might want to install the `Texinfo' package or
the `GNU make' package. Grab either from any GNU archive site.
make[3]: *** [bfd.info] Error 1
make[3]: Leaving directory `/home/rsg/rtems/tools/b-binutils/bfd/doc'
Making info in po
make[3]: Entering directory `/home/rsg/rtems/tools/b-binutils/bfd/po'
make[3]: Nothing to be done for `info'.
make[3]: Leaving directory `/home/rsg/rtems/tools/b-binutils/bfd/po'
make[3]: Entering directory `/home/rsg/rtems/tools/b-binutils/bfd'
make[3]: Nothing to be done for `info-am'.
make[3]: Leaving directory `/home/rsg/rtems/tools/b-binutils/bfd'
make[2]: *** [info-recursive] Error 1
make[2]: Leaving directory `/home/rsg/rtems/tools/b-binutils/bfd'
make[1]: *** [all-bfd] Error 2
make[1]: Leaving directory `/home/rsg/rtems/tools/b-binutils'
make: *** [all] Error 2
Any ideas?
Thanks,
-Bob
