4.9 Testing Request
Robert S. Grimes rsg at alum.mit.edu
Thu Sep 18 01:11:26 UTC 2008
I'm having trouble installing the 4.9-testing code with 4.10 tools.  It
builds just fine, but fails during the installation.
Here is the end of the build output:
 /usr/bin/install -c -m 644
'../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/barrier.inl'
'/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/barrier.inl'
'../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/rwlock.inl'
'/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/rwlock.inl'
'../../../../../../rtems-cvs-20080911/c/src/../../cpukit/posix/inline/rtems/posix/spinlock.inl'
'/usr/rtems/4.9/powerpc-rtems/virtex/lib/include/rtems/posix/spinlock.inl'
test -z "/usr/rtems/4.9/powerpc-rtems/virtex/lib" || /bin/mkdir -p
 /usr/bin/install -c -m 644 'libposix.a'
'/usr/rtems/4.9/powerpc-rtems/virtex/lib/libposix.a'
 powerpc-rtems-ranlib '/usr/rtems/4.9/powerpc-rtems/virtex/lib/libposix.a'
/bin/bash: line 4: powerpc-rtems-ranlib: command not found
make[5]: *** [install-project_libLIBRARIES] Error 127
make[5]: Leaving directory
`/home/rsg/rtems/tools/b-rtems-4.9-testing/powerpc-rtems/c/virtex/cpukit/posix'
make[4]: *** [install-am] Error 2
make[4]: Leaving directory
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
`/home/rsg/rtems/tools/b-rtems-4.9-testing/powerpc-rtems/c/virtex/cpukit'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory
`/home/rsg/rtems/tools/b-rtems-4.9-testing/powerpc-rtems/c/virtex'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
`/home/rsg/rtems/tools/b-rtems-4.9-testing/powerpc-rtems/c'
make: *** [install-recursive] Error 1
Seems it can't find powerpc-rtems-ranlib, yet it does exist, and in the
same directory as the other tools, so the path is correct.  Any ideas?
Thanks,
-Bob
Joel Sherrill wrote:
> Hi,
> The 4.9 branch has been cut and as I mentioned
> earlier we are in a period of testing and polishing.
> I request your assistance in testing on as many
> hardware platforms as possible.
> There is a tarball of the 4.9 branch along with
> a set of pre-built ticker.exe files for (I hope)
> all BSPs at:
> http://www.rtems.org/ftp/pub/rtems/people/joel/4.9-testing/2008-09-11/
> Please report your luck on the list and update
> this section of the 4.9 release notes wiki page.
> http://www.rtems.org/wiki/index.php/4.9_Release_Notes#BSPs_Reported_to_Work
> Let's verify what works and fix the BSPs that don't
> before 4.9.0 is released.
> Thanks.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.com
