filerdback (file read-back) sample app
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 2 13:18:35 UTC 2008
Gene Smith wrote:
> Has anyone tried to run this "filerdback" sample app. I get an error (-1
> returned) when tries to write to a file. Should this work? I enabled
> POSIX and it made no difference (wasn't sure if it is needed). Here's
> what I see:
> BUFSIZ = 1024
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> Wrote -1
> EXECUTIVE SHUTDOWN! Any key to reboot...
Runs now. It was an old user bug report and hadn't been updated
to have a correct configuration. It had a couple of obvious things
to correct.
Index: test.c
RCS file: /usr1/CVS/examples/filerdback/test.c,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -r1.6 -r1.7
--- test.c 23 Apr 2008 13:52:05 -0000 1.6
+++ test.c 2 Sep 2008 13:17:20 -0000 1.7
@@ -54,6 +54,8 @@
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
#define CONFIGURE_INIT
> Thanks,
> -gene
> rtems-users mailing list
> rtems-users at rtems.com
