powerpc interrupt handling
Kate Feng feng1 at bnl.gov
Thu Apr 2 15:52:48 UTC 2009
Sebastian Huber wrote:
> Jennifer Averett wrote:
>> I'm working with RTEMS 4.9 at an offsite location and am a little
>> confused about what the correct interrupt handler call to use for new
>> and updated powerpc ports.  There seem to be several that exist.
>> rtems_interrupt_handler_install
> This one if it is available (= BSPs that use
> c/src/lib/libbsp/shared/include/irq-generic.h etc.)
>> bsp_interrupt_handler_install
> In which header file is this one?
>> BSP_install_rtems_irq_handler/BSP_install_rtems_shared_irq_handler
> These are from my point of view obsolete.
Not from my point of view.
are for  BSP  that uses powerpc new-exceptions.  However, I would like
to suggest if it could be combined into one name as
The BSP_SHARED_HANDLER_SUPPORT defined in irq/irq.h would
decide if it should be shared or not.
Just a thought or suggestion.
Kate
>> Thanks
>> Jennifer Averett
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
