bug in lm32 port
Mon Apr 6 21:33:13 UTC 2009
All of this is committed.  Thanks.
It still does not address the fact that the interrupt processing
doesn't do the scheduling/dispatching right.  But moving that way.
--joel
Michael Walle wrote:
>> We could move both crt0 and _ISR_Handler to the .boot section. Wouldn't
>> that work?
>> I just noticed crt0 does use immediate call to boot_card...
> Hi,
> attached is a patch that fixes this issue. The vectors now use indirect calls
> both for the reset and the interrupt vector.
> For the reset vector we can basically use any register (expect for r1-r3 which
> are the arguments for boot_card()).
> For the interrupt vector, we can't use any other register than r0 without
> saving them to the stack. (_ISR_Handler clears r0 right at the beginning)
> @Jukka:
> The unused vectors destroy r7 before jumping to the debug handler (that may
> not be existent at all).
> Maybe it is better to jump to dead_end or anything like a panic screen (if
> that is possible with rtems). What was your intention to 'manually' jump to
> DEBA? Maybe im getting something wrong here.
> The real debug traps always maps to the DEBA base address.
