Build now works, new failure.
Andrew Sporner asporner at googlemail.com
Tue Apr 14 06:28:29 UTC 2009
Hi Chris,
Thanks!  that worked!!!
Andy
On Mon, Apr 13, 2009 at 11:46 PM, Chris Johns <chrisj at rtems.org> wrote:
> Andrew Sporner wrote:
>> Actually yes,
> Please remove the cpukit rpm. It does not seem it can be installed when
> building RTEMS samples and tests.
> This should fix the build.
> Regards
> Chris
