Has anyone ponied up to the update of TCP/IP yet?
Thomas Dörfler Thomas.Doerfler at imd-systems.de
Wed Apr 15 17:05:27 UTC 2009
Hi,
sorry for being silent on that issue (USB) for so long. We have received
your USB port package and after some inspection came to the conclusion
that in the long term it would be better to port the USB functinality
from FreeBSD to RTEMS, but with a more complete "FreeBSD porting layer".
The benefits from that approach are:
- have a more modern USB stack (which may even include client functinality)
- have the capability to upgrade to newer FreeBSD packages with low effort
- have the capability to upgrade the TCP/IP stack with low effort
- keep much closer to the FreeBSD sources WRT these two stacks and their
drivers
This work is already in progress.
wkr,
Thomas Doerfler.
xu ray wrote:
> No one has claimed as a mentor for this project yet.
> However, my friend and I are on the way to merge the USB stack from
> NetBSD now. We choose NetBSD because it is more friendly to different
> architectures.
> If you will begin to merge the new BSD TCP/IP. I think it will be a
> good idea to work together because there are lots of common codes
> (esp, the BSD header file and the OS adaptor layer)
> 2009/4/14 Andrew Sporner <asporner at googlemail.com>:
>> I am curious if this "open task" has been claimed.
>> If not I would be eager to take it on.  I have been working in the TCP/IP
>> area for about 10 years now and know the FreeBSD stack fairly well
>> (as well as that kernel fairly well).
>> Cheers
>> Andy
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
