rtems_iterate_over_all_threads
Wed Apr 22 13:33:34 UTC 2009
Leon Pollak wrote:
> Hello, all.
> I was glad to find the new rtems_iterate_over_all_threads API function
> - a useful thing in my case. What I want is to suspend temporary all
> tasks (except this which issues this command) and then, later, may be
> resume them.
> Great! But then I found a real obstacle to do this - to avoid myself
> suspension I need to compare myself ID with the "current" ID. For
> this, in turn, I need to use rtems_task_ident... Too complex and time
> consuming!
> Will not it be better to add a parameter to
> rtems_iterate_over_all_threads saying to avoid myself ID while iterating?
You could call rtems_task_self() or just compare the TCB to
_Thread_Executing.
> Thanks.
> Leon
