ORMANCEY Nicolas wrote: > From which files the config.sub is generated at boostrap time. config.sub is not generated - It is a separate GNU project of its own, with an upstream of its own. => You can not add cpus ad lib. When bootstrapping an RTEMS source-tree, RTEMS receives it from automake. Ralf
