config.sub generation bug?
ORMANCEY Nicolas
nicolas.ormancey at sogeti.com
Thu Apr 2 16:14:03 UTC 2009
Hi Ralf,
The file config.sub isn't present in the source tree before the bootstrap
command and the data that it contains are function of some configuration
files.
So my question is which configuration file are read to create the config.sub
file
What do you mean by :You can not add cpus ad lib.
Thanks
Nicolas
-----Message d'origine-----
De : Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
Envoyé : jeudi 2 avril 2009 16:15
À : ORMANCEY Nicolas
Cc : rtems-users at rtems.com
Objet : Re: config.sub generation bug?
ORMANCEY Nicolas wrote:
> From which files the config.sub is generated at boostrap time.
config.sub is not generated - It is a separate GNU project of its own,
with an upstream of its own.
=> You can not add cpus ad lib.
When bootstrapping an RTEMS source-tree, RTEMS receives it from automake.
Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20090402/bc1cc765/attachment-0001.html>
